Build(deps): Bump unf_ext from 0.0.7.7 to 0.0.8 (PR #14342)
Bumps unf_ext from 0.0.7.7 to 0.0.8.
Changelog
Sourced from unf_ext's changelog.
0.0.8
  • No functional change in the library code.
  • Include Windows binaries for Ruby 3.0.
  • Drop support for Ruby 2.1 and earlier.
  • Replace Travis CI with Github Actions.
  • Fix cross-build after upgrading rake-compiler/rake-compiler-dock to 1.1.1/1.1.0.
Commits
  • 2459d8c Bump the VERSION to 0.0.8
  • 2822b86 Build a source gem as well
  • a02051c Upgrade rake-compiler/rake-compiler-dock to 1.1.1/1.1.0
  • 8b25ab1 Merge pull request #64 from tablecheck/github-actions
  • 127cf65 Add Github Actions CI support.
  • f2ba120 Add GitHub Actions, trim jobs from Travis
  • See full diff in compare view
GitHub
