Build(deps): Bump unicode-display_width from 2.0.0 to 2.1.0 (PR #14348)
Bumps unicode-display_width from 2.0.0 to 2.1.0.
Changelog
Sourced from unicode-display_width's changelog.
2.1.0
  • Unicode 14.0
Commits
GitHub
