Build(deps): Bump uniform_notifier from 1.14.1 to 1.14.2 (PR #12516)
Bumps uniform_notifier from 1.14.1 to 1.14.2.
Changelog
Sourced from uniform_notifier's changelog.
1.14.2 (03/24/2021)
  • Fix capture_exception signature
Commits
GitHub
