Build(deps): Bump websocket-extensions from 0.1.3 to 0.1.4 in /app/assets/javascripts/pretty-text (PR #10617)
Bumps websocket-extensions from 0.1.3 to 0.1.4.
Changelog
Sourced from websocket-extensions's changelog.
0.1.4 / 2020-06-02
  • Remove a ReDoS vulnerability in the header parser (CVE-2020-7662, reported by Robert McLaughlin)
  • Change license from MIT to Apache 2.0
Commits
  • 8efd0cd Bump version to 0.1.4
  • 3dad4ad Remove ReDoS vulnerability in the Sec-WebSocket-Extensions header parser
  • 4a76c75 Add Node versions 13 and 14 on Travis
  • 44a677a Formatting change: {...} should have spaces inside the braces
  • f6c50ab Let npm reformat package.json
  • 2d211f3 Change markdown formatting of docs.
  • 0b62083 Update Travis target versions.
  • 729a465 Switch license to Apache 2.0.
  • See full diff in compare view
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
