Dependabot is rebasing this PR
If you make any changes to it yourself then they will take precedence over the rebase.
Bumps y18n from 4.0.0 to 4.0.1.
Changelog
Sourced from y18n's changelog.
Change Log
All notable changes to this project will be documented in this file. See standard-version for commit guidelines.
5.0.5 (2020-10-25)
Bug Fixes
5.0.4 (2020-10-16)
Bug Fixes
5.0.3 (2020-10-16)
Bug Fixes
5.0.2 (2020-10-01)
Bug Fixes
5.0.1 (2020-09-05)
Bug Fixes
5.0.0 (2020-09-05)
⚠ BREAKING CHANGES
- exports maps are now used, which modifies import behavior.
- drops Node 6 and 4. begin following Node.js LTS schedule (#89)
Features
... (truncated)
Commits
- See full diff in compare view
Maintainer changes
This version was pushed to npm by oss-bot, a new releaser for y18n since your current version.
Dependabot will resolve any conflicts with this PR as long as you don’t alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase
@dependabot rebase
will rebase this PR -
@dependabot recreate
will recreate this PR, overwriting any edits that have been made to it -
@dependabot merge
will merge this PR after your CI passes on it -
@dependabot squash and merge
will squash and merge this PR after your CI passes on it -
@dependabot cancel merge
will cancel a previously requested merge and block automerging -
@dependabot reopen
will reopen this PR if it is closed -
@dependabot close
will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually -
@dependabot ignore this major version
will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) -
@dependabot ignore this minor version
will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) -
@dependabot ignore this dependency
will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) -
@dependabot use these labels
will set the current labels as the default for future PRs for this repo and language -
@dependabot use these reviewers
will set the current reviewers as the default for future PRs for this repo and language -
@dependabot use these assignees
will set the current assignees as the default for future PRs for this repo and language -
@dependabot use this milestone
will set the current milestone as the default for future PRs for this repo and language
You can disable automated security fix PRs for this repo from the Security Alerts page.
