Build(deps): Bump zeitwerk from 2.3.1 to 2.4.0 (PR #10236)
Bumps zeitwerk from 2.3.1 to 2.4.0.
Changelog
Sourced from zeitwerk's changelog.
2.4.0 (15 July 2020)
  • Zeitwerk::Loader#push_dir supports an optional namespace keyword argument. Pass a class or module object if you want the given root directory to be associated with it instead of Object. Said class or module object cannot be reloadable.
  • The default inflector is even more performant.
Commits
GitHub
looks pretty safe, everything is passing.
