Build(deps): Bump zeitwerk from 2.4.0 to 2.4.1 (PR #11071)
Bumps zeitwerk from 2.4.0 to 2.4.1.
Changelog
Sourced from zeitwerk's changelog.
2.4.1 (29 October 2020)
  • Use __send__ instead of send internally.
Commits
GitHub
