Build(deps-dev): Bump better_errors from 2.7.0 to 2.7.1 (PR #9767)
Bumps better_errors from 2.7.0 to 2.7.1.
Release notes
Sourced from better_errors's releases.
v2.7.1
  • Show location of error in ActionView template error #463
Commits
  • 355966b Release 2.7.1
  • 7c063ad Merge pull request #463 from BetterErrors/feature/action-view-template-error-...
  • 73c02ed Show file and line within ActionView template
  • See full diff in compare view
GitHub
