Build(deps-dev): Bump better_errors from 2.7.1 to 2.8.0 (PR #10676)
Bumps better_errors from 2.7.1 to 2.8.0.
Release notes
Sourced from better_errors's releases.
v2.8.0
  • Support for Rails ActionableError #465
  • Allow editor links to work inside an iframe or with CSP that prohibits other protocols #440
  • Add CSRF protection to internal requests #474
  • Validate internal request method names #475
Commits
  • 3939536 Release 2.8.0
  • 50b4257 Merge pull request #475 from BetterErrors/feature/correct-xhr-mime-type
  • aa073f6 Validate internal call method names
  • 446c192 Validate content-type of internal calls
  • 8e8e796 Merge pull request #474 from BetterErrors/feature/add-csrf-to-requests
  • 4f05b45 Middleware specs to cover more CSRF edge cases
  • ef06461 Work around weirdness in older Rack::Response
  • 764bf3b Fix incorrect mime type in JSON error responses
  • 617e65e Add CSRF to error page and internal calls
  • 86c19fc Merge pull request #440 from lastobelus/add-target-to-editor-link
  • Additional commits viewable in compare view
GitHub
