Build(deps-dev): Bump bullet from 6.1.4 to 6.1.5 (PR #14057)
Bumps bullet from 6.1.4 to 6.1.5.
Changelog
Sourced from bullet's changelog.
6.1.5 (08/16/2021)
  • Rename whitelist to safelist
  • Fix onload called twice
  • Support Rack::Files::Iterator responses
  • Ensure HABTM associations are not incorrectly labeled n+1
Commits
  • 371beec move CI from travis to github actions
  • 40c0de0 require rack/files if exists
  • 5c70939 Bumping version to 6.1.5
  • 81b8820 Rename whitelist to safelist
  • 0658d53 Merge pull request #511 from rhymes/rhymes/rename-whitelist-to-safelist
  • 6d5edca Merge branch 'master' into rhymes/rename-whitelist-to-safelist
  • e44e375 Merge pull request #581 from TangentialSolutions/tbroevi/correct-labeling-for...
  • 660a05a Bug: Ensure HABTM associations are not incorrectly labeled n+1
  • 1d06a92 Merge pull request #576 from spdawson/support-rack-files-iterator-responses
  • d0288e6 Support Rack::Files::Iterator responses
  • Additional commits viewable in compare view
GitHub
