Build(deps-dev): Bump byebug from 11.1.1 to 11.1.2 (PR #9462)
Bumps byebug from 11.1.1 to 11.1.2.
Release notes
Sourced from byebug's releases.
11.1.2
Fixed
  • #657: crash when hitting <TAB> due to IRB completion mechanism included in the default ruby 2.7 version of the irb gem ([@terceiro]).
... (truncated)
Changelog
Sourced from byebug's changelog.
[11.1.2] - 2020-04-17
Fixed
Commits
  • 27f84f6 Merge pull request #672 from deivid-rodriguez/release/v11.1.2
  • b3e02eb Get ready for 11.1.2 release
  • 9ecdaf3 Fix unreleased diff link in changelog
  • 7c4aad4 Fix crash on TAB under ruby 2.7 (#657)
  • a3da24e Merge pull request #671 from deivid-rodriguez/avoid_simplecov_on_new_rubies
  • 9539053 Always avoid coverage on newer rubies
  • a05ce25 Rename local variable for clarify
  • 3bbb004 Simplify computation of a local path
  • 7aaa05a Bump rubocop from 0.81.0 to 0.82.0 (#670)
  • 5fa9a39 Bump pry from 0.13.0 to 0.13.1 (#669)
  • Additional commits viewable in compare view
GitHub
