Build(deps-dev): Bump byebug from 11.1.2 to 11.1.3 (PR #9540)
Bumps byebug from 11.1.2 to 11.1.3.
Release notes
Sourced from byebug's releases.
11.1.3
Fixed
  • #674: crash when using byebug on ruby 2.7.0 on Windows.
... (truncated)
Changelog
Sourced from byebug's changelog.
[11.1.3] - 2020-04-23
Fixed
Commits
GitHub
