Build(deps-dev): Bump discourse_dev from 0.0.9 to 0.1.0 (PR #12723)
Bumps discourse_dev from 0.0.9 to 0.1.0.
Commits
  • 31dc778 FIX: add default email for new user.
  • 9d84114 FEATURE: add discourse-development-auth plugin as fake auth provider.
  • 53e62d4 FEATURE: create default admin account from input with optional password.
  • See full diff in compare view
GitHub
Looks like discourse_dev is up-to-date now, so this is no longer needed.
