Build(deps-dev): Bump discourse_dev from 0.1.0 to 0.2.0 (PR #12844)
Bumps discourse_dev from 0.1.0 to 0.2.0.
Commits
  • c1c065b Bump version
  • 7dab215 FEATURE: Config for the number of created topics, users,...
  • ddf9cff FIX: Finding a topic title failed when creating >30 topics
  • 9e5a688 FIX: Ensure valid usernames are created
  • 17d07f9 FIX: Prevent Faker from resetting multiple times
  • 76c7da2 REFACTOR: Simplify config
  • 8b5500f DEV: Add Rubocop
  • c9903d3 FEATURE: Setting for populating posts with images (#4)
  • 2d5fd59 FIX: Support Rails 6.1 (#3)
  • See full diff in compare view
GitHub
