Build(deps-dev): Bump fabrication from 2.21.0 to 2.21.1 (PR #9341)
Bumps fabrication from 2.21.0 to 2.21.1.
Changelog
Sourced from fabrication's changelog.
2.21.1
  • Fix bug where nil property overrides could be ignored (#318)
Commits
GitHub
