Build(deps-dev): Bump faker from 2.18.0 to 2.19.0 (PR #14126)
Bumps faker from 2.18.0 to 2.19.0.
Release notes
Sourced from faker's releases.
v2.19.0
The 2.19.0 version includes:
  • new Faker generators
  • bug fixes
  • update locales
Changelog
Sourced from faker's changelog.
v2.19.0 (2021-08-22)
Bug/Fixes
Feature Request
Update locales
Update local dependencies
  • Update rubocop requirement from = 1.18.3 to = 1.18.4 (#2362)
  • Update rake requirement from = 13.0.3 to = 13.0.6 (#2357)
  • Update rubocop requirement from = 1.18.1 to = 1.18.3 (#2353)
  • Update rubocop requirement from = 1.17.0 to = 1.18.1 (#2346)
  • Update rubocop requirement from = 1.16.0 to = 1.17.0 (#2337)
  • Update test-unit requirement from = 3.4.2 to = 3.4.4 (#2334)
  • Update rubocop requirement from = 1.15.0 to = 1.16.0 (#2332)
  • Update test-unit requirement from = 3.4.1 to = 3.4.2 (#2331)
  • Update rubocop requirement from = 1.14.0 to = 1.15.0 (#2325)
Commits
GitHub
