Build(deps-dev): Bump listen from 3.5.1 to 3.6.0 (PR #13816)
Bumps listen from 3.5.1 to 3.6.0.
Release notes
Sourced from listen's releases.
v3.6.0
✨ New Features
Commits
  • 0f2662a release v3.6.0
  • 2693d44 issue #452: use SHA256 instead of MD5 for FIPS compatibility
  • 96c9476 update README to remove FreeBSD limitation and stale reference to Travis CI
  • See full diff in compare view
GitHub
