Build(deps-dev): Bump minitest from 5.14.1 to 5.14.2 (PR #10576)
Bumps minitest from 5.14.1 to 5.14.2.
Changelog
Sourced from minitest's changelog.
=== 5.14.2 / 2020-08-31
  • 1 bug fix:
    • Bumped ruby version to include 3.0 (trunk).
Commits
  • dc6ad17 prepped for release
  • 9713c55 - Bumped ruby version to include 3.0 (trunk).
  • acbcece whitespace
  • 0e6c44a I am an idiot... fixed a last-day-of-month testing bug. I don't think I've do...
  • See full diff in compare view
GitHub
