Build(deps-dev): Bump mocha from 1.12.0 to 1.13.0 (PR #13538)
Bumps mocha from 1.12.0 to 1.13.0.
Changelog
Sourced from mocha's changelog.
1.13.0
External changes
  • Add ParameterMatchers#has_keys - thanks to @​cstyles for #512 (18d8104)
  • Fix misleading exception message in ParameterMatchers#has_entry - thanks to @​cstyles for #513 (9c4ef13)
  • Only add dependency on rubocop if we're actually going to use it (f2f879f)
  • Fix rake dependency constraints for older Ruby versions (7ce5f29)
Internal changes
  • Check documentation can be generated as part of CircleCI build (b30d9a9)
  • Add --fail-on-warning option to yard rake task (53a6ee3)
  • Add a weekly scheduled build to the CircleCI build (fd2a4c6)
  • Add Ruby v1.8 to the CircleCI build matrix (818ca03)
  • Add API token to fix CircleCI badge in README (607c5aa)
  • Provide wrapped option for #mocha_inspect on hashes & arrays (d8f44bc)
  • Use CircleCI instead of TravisCI for automated builds (c98c6ec)
  • Switch to newer default Travis CI build env (c78f75c)
  • Use latest Ruby versions in Travis CI builds (9e0043a)
  • Use latest JRuby v9.2.18 in Travis CI builds (8c99a1b)
  • Use consistent JRuby versions in Travis CI builds (0f849aa)
  • Use more recent version of JRuby in Travis CI build matrix (58653db)
Commits
  • 191823e [skip ci] Update documentation for v1.13.0 release
  • f59385e Bump version to 1.13.0 & prepare for release
  • b30d9a9 Check documentation can be generated as part of CircleCI build
  • 53a6ee3 Add --fail-on-warning option to yard rake task
  • fd2a4c6 Add a weekly scheduled build to the CircleCI build
  • 818ca03 Add Ruby v1.8 to the CircleCI build matrix
  • 607c5aa Add API token to fix CircleCI badge in README
  • 18d8104 Add ParameterMatchers#has_keys
  • d8f44bc Provide wrapped option for #mocha_inspect on hashes & arrays
  • 9c4ef13 Fix misleading exception message in ParameterMatchers#has_entry
  • Additional commits viewable in compare view
GitHub
