Build(deps-dev): Bump mock_redis from 0.22.0 to 0.23.0 (PR #9506)
Bumps mock_redis from 0.22.0 to 0.23.0.
Release notes
Sourced from mock_redis's releases.
0.23.0
  • Raise error when setex called with negative timeout (#174)
  • Add support for dump/restore between MockRedis instances (#176)
  • Fix warnings for ZSET methods on Ruby 2.7 (#177)
  • Add support for returning time in pipelines (#179)
  • Fix SET methods to correct set milliseconds with px (#180)
  • Add support for unsorted sets within zinterstore/zunionstore(#182)
Changelog
Sourced from mock_redis's changelog.
0.23.0
Commits
  • 72a1c34 Cut version 0.23.0
  • 16d0078 support for unsorted sets within zinterstore/zunionstore (#182)
  • e7cef50 fix: correctly set milliseconds ttl for set with px (#180)
  • 5ef8f8b feat: support returning time in pipelines (#179)
  • 1a1f716 Do not call =~ on Integer (#177)
  • 146beda Add support for dump/restore between MockRedis instances (#176)
  • e8dc650 Update change log with setex negative timeout fix
  • 62cfc3c Raise Redis::CommandError error when setex called with a negative timeout (#174)
  • See full diff in compare view
GitHub
