Build(deps-dev): Bump mock_redis from 0.23.0 to 0.24.0 (PR #10075)
Bumps mock_redis from 0.23.0 to 0.24.0.
Release notes
Sourced from mock_redis's releases.
0.24.0
  • Fix handling of blocks within multi blocks (#185)
  • Fix handling of multiple consecutive ? characters in key pattern matching (#186)
  • Change exists to return an integer and add exists? (#188)
Changelog
Sourced from mock_redis's changelog.
0.24.0
Commits
  • c4651c7 Cut version 0.24.0
  • 166c8bb Change exists return and add exists? (#188)
  • d7d9352 properly handle multiple consecutive ? characters when doing keys pattern m...
  • 09747cb Handle block within multi block (#185)
  • 80c1297 Update RuboCop 0.68.1 → 0.82.0
  • d397cb3 Update Overcommit 0.48.0 → 0.53.0 for CI
  • 3479cc9 Fix RuboCop warning
  • See full diff in compare view
GitHub
