Build(deps-dev): Bump mock_redis from 0.24.0 to 0.25.0 (PR #10123)
Bumps mock_redis from 0.24.0 to 0.25.0.
Release notes
Sourced from mock_redis's releases.
0.25.0
  • Add support for xread command (#190)
  • Fix mget to raise error when passing empty array (#191)
  • Fix xadd when maxlen is zero (#192)
Changelog
Sourced from mock_redis's changelog.
0.25.0
Commits
GitHub
