Build(deps-dev): Bump mock_redis from 0.25.0 to 0.26.0 (PR #10536)
Bumps mock_redis from 0.25.0 to 0.26.0.
Changelog
Sourced from mock_redis's changelog.
0.26.0
  • Add block and count support to xread (#194)
Commits
GitHub
