Build(deps-dev): Bump mock_redis from 0.27.3 to 0.28.0 (PR #12923)
Bumps mock_redis from 0.27.3 to 0.28.0.
Release notes
Sourced from mock_redis's releases.
0.28.0
  • Fix hmset exception (#206)
  • Fix hmset to accept hashes in addition to key/value pairs (#208)
  • Fix stream ID regex to support ( (#209)
  • Allow mget to accept a block (#210)
Changelog
Sourced from mock_redis's changelog.
0.28.0
Commits
GitHub
