Build(deps-dev): Bump mock_redis from 0.28.0 to 0.29.0 (PR #14034)
Bumps mock_redis from 0.28.0 to 0.29.0.
Release notes
Sourced from mock_redis's releases.
0.29.0
  • Add support for logger option (#211)
  • Fix zadd to not perform conditional type conversion (#214)
  • Fix hdel to raise error when called with empty array (#215)
Changelog
Sourced from mock_redis's changelog.
0.29.0
Commits
GitHub
