Build(deps-dev): Bump parallel_tests from 3.0.0 to 3.1.0 (PR #10306)
Bumps parallel_tests from 3.0.0 to 3.1.0.
Changelog
Sourced from parallel_tests's changelog.
3.1.0 - 2020-07-23
Added
  • --fail-fast stops all groups if one group fails. Can be used to stop all groups if one test failed by using fail-fast in the test-framework too (for example rspec via --test-options '--fail-fast' or in .rspec_parallel).
Commits
GitHub
