Build(deps-dev): Bump parallel_tests from 3.2.0 to 3.3.0 (PR #10684)
Bumps parallel_tests from 3.2.0 to 3.3.0.
Changelog
Sourced from parallel_tests's changelog.
3.3.0 - 2020-09-16
Added
  • Added support for multiple isolated processes.
Commits
GitHub
