Build(deps-dev): Bump parallel_tests from 3.5.2 to 3.6.0 (PR #12528)
Bumps parallel_tests from 3.5.2 to 3.6.0.
Changelog
Sourced from parallel_tests's changelog.
v3.6.0 - 2021-03-25
Breaking Changes
  • Drop ruby 2.4 support
Added
  • Run default test folder if no arguments are passed.
Fixed
  • None
v3.5.1 - 2021-03-07
Breaking Changes
  • None
Added
  • None
Fixed
  • Do not use db:structure for rails 6.1
v3.5.0 - 2021-02-24
Breaking Changes
  • None
Added
  • Add support for specifying exactly how isolated processes run tests with 'specify-groups' option.
  • Refactorings for rubocop
Fixed
  • None
v3.4.0 - 2020-12-24
Breaking Changes
  • None
Added
... (truncated)
Commits
GitHub
