Build(deps-dev): Bump parallel_tests from 3.6.0 to 3.7.0 (PR #12657)
Bumps parallel_tests from 3.6.0 to 3.7.0.
Changelog
Sourced from parallel_tests's changelog.
v3.7.0 - 2021-04-08
Breaking Changes
  • None
Added
  • Added --highest-exit-status option to return the highest exit status to allow sub-processes to send things other than 1
Fixed
  • None
Commits
  • 9a14139 v3.7.0
  • e6b6d38 Adding --highest-exit-status which returns the highest exit status from test ...
  • See full diff in compare view
GitHub
