Build(deps-dev): Bump parallel_tests from 3.7.0 to 3.7.1 (PR #14048)
Bumps parallel_tests from 3.7.0 to 3.7.1.
Changelog
Sourced from parallel_tests's changelog.
Changelog
Unreleased
Breaking Changes
  • None
Added
  • None
Fixed
  • All cucumber options are now pushed to the end of the command invocation
    • Fixes an issue where the --retry flag wouldn't work correctly
Commits
GitHub
