Build(deps-dev): Bump rb-fsevent from 0.10.3 to 0.10.4 (PR #9599)
Bumps rb-fsevent from 0.10.3 to 0.10.4.
Release notes
Sourced from rb-fsevent's releases.
v0.10.4
  • Remove bundler development dependency #85
Commits
GitHub
