Build(deps-dev): Bump rspec-rails from 4.0.0 to 4.0.1 (PR #9804)
Bumps rspec-rails from 4.0.0 to 4.0.1.
Changelog
Sourced from rspec-rails's changelog.
4.0.1 / 2020-05-16
Full Changelog
Bug Fixes:
  • Remove warning when calling driven_by in system specs. (Aubin Lorieux, #2302)
  • Fix comparison of times for #at in job matchers. (Jon Rowe, Markus Doits, #2304)
  • Allow have_enqueued_mail to match when a sub class of ActionMailer::DeliveryJob is set using <Class>.delivery_job=. (Atsushi Yoshida #2305)
  • Restore Ruby 2.2.x compatibility. (Jon Rowe, #2332)
  • Add required_ruby_version to gem spec. (Marc-André Lafortune, #2319, #2338)
Commits
GitHub
