Build(deps-dev): Bump rubocop-discourse from 2.2.0 to 2.3.0 (PR #10278)
Bumps rubocop-discourse from 2.2.0 to 2.3.0.
GitHub
@tgxworld it looks like the latest rules have a lot of failures that need to be fixed?
Looks like rubocop-discourse is up-to-date now, so this is no longer needed.
