Build(deps-dev): Bump rubocop-discourse from 2.2.0 to 2.3.1 (PR #10307)
Bumps rubocop-discourse from 2.2.0 to 2.3.1.
GitHub
Looks like rubocop-discourse is up-to-date now, so this is no longer needed.
