Build(deps-dev): Bump rubocop-discourse from 2.3.2 to 2.4.0 (PR #11078)
Bumps rubocop-discourse from 2.3.2 to 2.4.0.
Commits
GitHub
OK, I won’t notify you again about this release, but will get in touch when a new version is available. If you’d rather skip all updates until the next major or minor version, let me know by commenting @dependabot ignore this major version or @dependabot ignore this minor version.
If you change your mind, just re-open this PR and I’ll resolve any conflicts on it.
