Build(deps-dev): Bump rubocop from 0.81.0 to 0.82.0 (PR #9452)
Bumps rubocop from 0.81.0 to 0.82.0.
Release notes
Sourced from rubocop's releases.
RuboCop 0.82
New features
Bug fixes
  • #7871: Fix an auto-correction bug in Lint/BooleanSymbol. (@knu)
  • #7842: Fix a false positive for Lint/RaiseException when raising Exception with explicit namespace. (@koic)
  • #7834: Fix Lint/UriRegexp to register offense with array arguments. (@tejasbubane)
  • #7841: Fix an error for Style/TrailingCommaInBlockArgs when lambda literal (->) has multiple arguments. (@koic)
  • #7842: Fix a false positive for Lint/RaiseException when Exception without cbase specified under the namespace Gem by adding AllowedImplicitNamespaces option. (@koic)
  • Style/IfUnlessModifier does not infinite-loop when autocorrecting long lines which use if/unless modifiers and have multiple statements separated by semicolons. (@alexdowad)
  • rubocop-hq/rubocop-rails#127: Use ConfigLoader.default_configuration for the default config. (@hanachin)
Changes
  • (Breaking) Renamed Layout/Tab cop to Layout/IndentationStyle. (@DracoAter)
  • #7869: (Breaking) Drop support for Ruby 2.3. (@koic)
Changelog
Sourced from rubocop's changelog.
0.82.0 (2020-04-16)
New features
  • #7867: Add support for tabs in indentation. ([@DracoAter][])
  • #7863: Corrector now accepts nodes in addition to ranges. ([@marcandre][])
  • #7862: Corrector now has a wrap method. ([@marcandre][])
  • #7850: Make it possible to enable/disable pending cops. ([@koic][])
  • #7861: Make it to allow Style/CaseEquality when the receiver is a constant. ([@rafaelfranca][])
  • #7851: Add a new Style/ExponentialNotation cop. ([@tdeo][])
  • #7384: Add new Style/DisableCopsWithinSourceCodeDirective cop. ([@egze][])
  • #7826: Add new Layout/SpaceAroundMethodCallOperator cop. ([@saurabhmaurya15][])
Bug fixes
  • #7871: Fix an auto-correction bug in Lint/BooleanSymbol. ([@knu][])
  • #7842: Fix a false positive for Lint/RaiseException when raising Exception with explicit namespace. ([@koic][])
  • #7834: Fix Lint/UriRegexp to register offense with array arguments. ([@tejasbubane][])
  • #7841: Fix an error for Style/TrailingCommaInBlockArgs when lambda literal (->) has multiple arguments. ([@koic][])
  • #7842: Fix a false positive for Lint/RaiseException when Exception without cbase specified under the namespace Gem by adding AllowedImplicitNamespaces option. ([@koic][])
  • Style/IfUnlessModifier does not infinite-loop when autocorrecting long lines which use if/unless modifiers and have multiple statements separated by semicolons. ([@alexdowad][])
  • rubocop-hq/rubocop-rails#127: Use ConfigLoader.default_configuration for the default config. ([@hanachin][])
Changes
  • (Breaking) Renamed Layout/Tab cop to Layout/IndentationStyle. ([@DracoAter][])
  • #7869: (Breaking) Drop support for Ruby 2.3. ([@koic][])
Commits
  • eb3d358 Cut 0.82.0
  • 960e4ec Fix a build error
  • 532b681 Use ConfigLoader.default_configuration for default (#7632)
  • fc24294 Fix a false positive for Layout/SpaceAroundMethodCallOperator
  • b54bb91 Avoid infinite loop when autocorrecting with Style/IfUnlessModifier
  • 940cec0 Fix the changelog
  • 6b9510d Add support for tabs in indentation (#7867)
  • 85ecd05 Add spec for warning messages when cache location is invalid
  • e22c2e2 Merge pull request #7875 from koic/enable_new_cops_for_rubocop_development
  • 3aac880 Enable NewCops for RuboCop development
  • Additional commits viewable in compare view
GitHub
Looks like rubocop is up-to-date now, so this is no longer needed.
