Build(deps-dev): Bump ruby-prof from 1.3.2 to 1.4.0 (PR #9761)
Bumps ruby-prof from 1.3.2 to 1.4.0.
Commits
  • 58b3563 Version 2.4.0
  • b46cbdd Visual studio updates.
  • 15f149f Update travis rubies. Remove ruby 1.4.* since it is no longer supported.
  • 2786658 Remove this no longer needed compiler check.
  • f3f89bf Fix #270.
  • 6fbce38 Add support for correctly loggin newobj events when profiling memory.
  • 0b1b96a Fix MSVC compiler warnings.
  • b246fd1 Remove a lot of old cruft that isn't used anymore.
  • dbb0e6f Remove merge fiber functionality since it can result in crashes. Fixes #266.
  • 9994861 Fix spelling mistake.
  • See full diff in compare view
GitHub
