Build(deps-dev): Bump shoulda-matchers from 4.3.0 to 4.4.1 (PR #10535)
Bumps shoulda-matchers from 4.3.0 to 4.4.1.
Release notes
Sourced from shoulda-matchers's releases.
v4.4.0
Features
  • Add an ignoring_check_for_db_index qualifier to the have_secure_token matcher, since has_secure_token encourages use of an index but does not enforce it. (#1278)
  • Add allow_blank to validate_length_of to match other validation matchers. (#725, #1318)
  • Add new matcher have_implicit_order_column which can be used to test the implicit_order_column setting for ActiveRecord models under Rails 6+. (#1243)
  • Add a new is_other_than qualifier to validate_numericality_of to be able to test the numericality validation's :other_than option. (#1282)
  • Add a new have_one_attached and have_many_attached matchers for testing the new model-level ActiveStorage macros in Rails 6. (#1102)
#1278: thoughtbot/shoulda-matchers#1278 #725: thoughtbot/shoulda-matchers#725 #1318: thoughtbot/shoulda-matchers#1318 #1243: thoughtbot/shoulda-matchers#1243 #1282: thoughtbot/shoulda-matchers#1282 #1102: thoughtbot/shoulda-matchers#1102
Bug fixes
  • Fix performance of allow_value so that it doesn't hang if the given value is really long. (#1290)
  • Fix have_many so that it is possible to test an association that has a scope that takes an argument. (#952, #992)
  • Update validate_uniqueness_of to use the public validators_on instead of the private _validators when reading validations off of a model. This enables shoulda-matchers to be used with the [schema_validations] gem. (#995)
  • Update validate_uniqueness_of to work with scopes that are time columns. (#1190)
  • Fix have_and_belong_to_many so that when using the join_table qualifier you can pass a symbol rather than a string. (#1323)
#1290: thoughtbot/shoulda-matchers#952 #952: thoughtbot/shoulda-matchers#952 #992: thoughtbot/shoulda-matchers#992 [schema_validations]: https://github.com/SchemaPlus/schema_validations
Changelog
Sourced from shoulda-matchers's changelog.
4.4.1 - 2020-08-26
Bug fixes
  • Revert reorganization around autoloading introduced in 4.4.0 which prevented matchers from being loaded. (#1334)
#1334: thoughtbot/shoulda-matchers#1334
4.4.0 - 2020-08-25
Bug fixes
#1290: thoughtbot/shoulda-matchers#952 #952: thoughtbot/shoulda-matchers#952 #992: thoughtbot/shoulda-matchers#992 [schema_validations]: https://github.com/SchemaPlus/schema_validations #995: thoughtbot/shoulda-matchers#995 #1190: thoughtbot/shoulda-matchers#1190 #1323: thoughtbot/shoulda-matchers#1323
Features
Commits
  • 4e84191 Release v4.4.1
  • 7d098c9 Revert "Use autoloading instead of requiring all files up front"
  • c8cd836 Release v4.4.0
  • e7dde36 Add have_attached_matcher to the Readme
  • 781bfca Update CHANGELOG
  • ce78101 Use autoloading instead of requiring all files up front
  • bd13bec Be consistent with order of headers in changelog
  • d1be1f7 Update CHANGELOG
  • 6a0e436 Remove warnings that fail the build
  • 412ea1f Use warnings_logger instead of warnings_spy
  • Additional commits viewable in compare view
GitHub
