Bumps shoulda-matchers from 4.4.1 to 4.5.0.
Release notes
Sourced from shoulda-matchers's releases.
v4.5.0
Features
- Add support for has_secure_password custom attributes. (#1356)
#1356: thoughtbot/shoulda-matchers#1356
Bug fixes
- Fix
bundle exec yard doc
replacing pygments.rb with rouge to keep the documentation up to date. (#1343)- Fix have_db_column.with_options not raising an error when the user adds an invalid value. (#1358)
- Fix default value of assossiation_matcher.validate option. It was returning false instead of true. (#1378)
- Fix validate_absence_of failing for array columns. (#1383)
#1340: thoughtbot/shoulda-matchers#1340 #1358: thoughtbot/shoulda-matchers#1358 #1378: thoughtbot/shoulda-matchers#1378 #1383: thoughtbot/shoulda-matchers#1383
Improvements
- Replace all links with http to https. (#1340)
- Update the links for have_and_belong_to_many, have_many and have_one in the README to redirect the user to where the matcher description starts. (#1348)
- Drop
git ls-files
in gemspec to help downstreams maintenance, because they often need to build packages in an environment that does not have git. (#1354)- Add comment about no support of validate_uniqueness_of(:item).scoped_to(array). (#1355)
- Improve error message for assossiation_matcher.with_foreign_key option. (#1376)
#1343: thoughtbot/shoulda-matchers#1343 #1348: thoughtbot/shoulda-matchers#1348 #1354: thoughtbot/shoulda-matchers#1354 #1355: thoughtbot/shoulda-matchers#1355 #1376: thoughtbot/shoulda-matchers#1376
Changelog
Sourced from shoulda-matchers's changelog.
4.5.0 - 2020-12-28
Bug fixes
- Fix
Features
Improvements
- Drop
git ls-files
Commits
5d48d37
Release v4.5.0 (#1389) -
81c886e
Update license year (#1390) -
2bb82c3
Bring CHANGELOG up to date (#1387) -
9b0b5c9
Fix RuboCop offenses -
63b6321
fix have_db_column.with_options misspelled options -
e19ebf2
Fix validate_absence_of failing for array columns -
3adbbf1
Fix 'required_ruby_version: unbound variable' (#1373) -
64376a0
fix: with_foreign_key modifier fails with wrong error message (#1376) -
8772cd4
fix: has_many without validate option returns false instead of true (#1378) -
bf41204
fix: Remove lint-action github action and add custom RuboCop action - Additional commits viewable in compare view
Dependabot will resolve any conflicts with this PR as long as you don’t alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase
@dependabot rebase
will rebase this PR -
@dependabot recreate
will recreate this PR, overwriting any edits that have been made to it -
@dependabot merge
will merge this PR after your CI passes on it -
@dependabot squash and merge
will squash and merge this PR after your CI passes on it -
@dependabot cancel merge
will cancel a previously requested merge and block automerging -
@dependabot reopen
will reopen this PR if it is closed -
@dependabot close
will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
