Build(deps-dev): Bump shoulda-matchers from 4.5.1 to 5.0.0 (PR #13699)
Bumps shoulda-matchers from 4.5.1 to 5.0.0.
Release notes
Sourced from shoulda-matchers's releases.
v5.0.0
Bug fixes
  • Replace in?, method from ActiveSupport, with include? to prevent exception "undefined method in?" on non-Rails app. (#1405)
#1405: thoughtbot/shoulda-matchers#1405
Features
  • Add support for Rails 6.1. No new Rails 6.1 features are supported, but only existing features that broke with the upgrade. (#1418)
  • Add support for RVM (Ruby Version Manager) to setting up local environment. (#1424)
  • Add support for alias in matcher define_enum. (#1419)
  • Add support for Ruby 3.0. (#1406, #1427)
#1406: thoughtbot/shoulda-matchers#1406 #1418: thoughtbot/shoulda-matchers#1418 #1419: thoughtbot/shoulda-matchers#1419 #1424: thoughtbot/shoulda-matchers#1424 #1427: thoughtbot/shoulda-matchers#1427
Improvements
  • Remove deprecated warnings emitted on Rails 6.1 in ActiveModel errors. (#1444)
#1444: thoughtbot/shoulda-matchers#1444
v5.0.0.rc1
Bug fixes
Features
... (truncated)
Changelog
Sourced from shoulda-matchers's changelog.
5.0.0 - 2021-07-09
Bug fixes
Features
Improvements
5.0.0.rc1 - 2021-06-04
Bug fixes
Features
... (truncated)
Commits
GitHub
