Build(deps-dev): Bump test-prof from 0.12.0 to 0.12.1 (PR #10571)
Bumps test-prof from 0.12.0 to 0.12.1.
Changelog
Sourced from test-prof's changelog.
0.12.1 (2020-09-01)
  • Minor improvements.
Commits
  • 03141e4 Bump 0.12.1
  • 900054b Fix let_it_be with Rails3 with no transactions
  • 526ab77 fix(docs): correct before_all + isolator instructions
  • 1422312 Run lefthook liche only when md changed
  • 6d5eecd fix(docs): grammar
  • 617b8bf rubocop 0.88 + test-prof 0.11+ don't play nice together. This fixes that
  • 63a106f docs: bring back readme
  • c922a2f docs: bring back sidebar and getting_started
  • 4b1c677 dev: add lefthook for docs
  • 2d79757 Reorganize docs
  • Additional commits viewable in compare view
GitHub
