Build(deps-dev): Bump test-prof from 0.12.1 to 0.12.2 (PR #10589)
Bumps test-prof from 0.12.1 to 0.12.2.
Changelog
Sourced from test-prof's changelog.
0.12.2 (2020-09-03)
  • Execute Minitest before_all in the context of the current test object. ([@palkan][])
Commits
GitHub
