Build(deps-dev): Bump test-prof from 1.0.3 to 1.0.4 (PR #13051)
Bumps test-prof from 1.0.3 to 1.0.4.
Release notes
Sourced from test-prof's releases.
1.0.4
Features
  • Add ability to use custom logger.
TestProf.configure do |config|
  config.logger = Logger.new($stdout, level: Logger::WARN)
  • Add nate_heckler mode for FactoryProf.
Drop this into your rails_helper.rb or test_helper.rb:
require "test_prof/factory_prof/nate_heckler"
And for every test run see the overall factories usage:
[TEST PROF INFO] Time spent in factories: 04:31.222 (54% of total time)
Changelog
Sourced from test-prof's changelog.
1.0.4 (2021-05-12)
  • Add ability to use custom logger. ([@​palkan][])
  • Add nate_heckler mode for FactoryProf. ([@​palkan][])
Commits
GitHub
