Build(deps-dev): Bump test-prof from 1.0.4 to 1.0.5 (PR #13061)
Bumps test-prof from 1.0.4 to 1.0.5.
Changelog
Sourced from test-prof's changelog.
1.0.5 (2021-05-13)
  • Fix logging regression when no newline has been added. ([@​palkan][])
Commits
  • 64c9c9b Bump 1.0.5
  • 133728d fix: use color logs only for tty io, initialize logger lazily
  • 6b06c71 fix(regression): add newlines to logs
  • 1a9c8ad ci: add force:true to push-stable workflow
  • See full diff in compare view
GitHub
