Build(deps-dev): Bump test-prof from 1.0.5 to 1.0.6 (PR #13511)
Bumps test-prof from 1.0.5 to 1.0.6.
Changelog
Sourced from test-prof's changelog.
1.0.6 (2021-06-23)
  • Fix Spring detection when DISABLE_SPRING=1 is used. ([@​palkan][])
  • Make before_all in Minitest inheritable. ([@​palkan][])
Commits
GitHub
