Build(deps-dev): Bump test-prof from 1.0.6 to 1.0.7 (PR #14193)
Bumps test-prof from 1.0.6 to 1.0.7.
Release notes
Sourced from test-prof's releases.
1.0.7
  • Added experimental support for using before_all with Rails' test parallelization using processes. Make sure to include TestProf::BeforeAll::Minitest before you call parallelize.
  • Fixed access to let_it_be variables in after(:all) hook.
Changelog
Sourced from test-prof's changelog.
1.0.7 (2021-08-30)
  • Fix access to let_it_be variables in after(:all) hook. ([@​cbarton][])
  • Add support for using the before_all hook with Rails' parallelize feature (using processes). ([@​peret][])
Commits
  • cc6a844 Bump 1.0.7
  • cd7e7fa fix: check that Rails is present, i.e. the including class supports #parallelize
  • b338412 fix: fix Rubocop warning and before_all test cases
  • f91c5c3 fix: deactivate before_all_executor after last test file per process
  • 4d7eb36 fix: call deactivate on the correct before_all_executor for parallel tests
  • d46ded4 feature: Add support for (process) parallelized tests to before_all for minit...
  • ef07109 Allow access to let_it_be defined variables in after(:context)
  • d70ee8f Documentation disable! typo
  • See full diff in compare view
GitHub
