Bumps webmock from 3.11.0 to 3.11.1.
Changelog
Sourced from webmock's changelog.
3.11.1
Compatibility with async-http 0.54+
Thanks to Jun Jiang
Commits
c2721df
Version 3.11.1 -
881c355
Merge pull request #923 from jasl/fix-compatible-with-async-http-0_54 -
8be4e93
Compatible with async-http 0.54+ - See full diff in compare view
Dependabot will resolve any conflicts with this PR as long as you don’t alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase
@dependabot rebase
will rebase this PR -
@dependabot recreate
will recreate this PR, overwriting any edits that have been made to it -
@dependabot merge
will merge this PR after your CI passes on it -
@dependabot squash and merge
will squash and merge this PR after your CI passes on it -
@dependabot cancel merge
will cancel a previously requested merge and block automerging -
@dependabot reopen
will reopen this PR if it is closed -
@dependabot close
will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
