Build(deps-dev): Bump webmock from 3.12.1 to 3.12.2 (PR #12541)
Bumps webmock from 3.12.1 to 3.12.2.
Changelog
Sourced from webmock's changelog.
3.12.2
  • Fixed em-http-request adapter to avoid calling middleware twice.
    Thanks to Alex Vondrak
Commits
  • 4d37538 Version 3.11.2
  • 6967c20 Merge branch 'ajvondt push origin master
  • 2b87ab3 Merge branch 'master' of github.com:ajvondrak/webmock into ajvondrak-master
  • 7437229 Removed trailing space.
  • d06f87f HTTP/2 doesn’t have dot in version number.
  • 443a4c7 Avoid redundantly calling em-http-request middleware
  • 6ff8c0a Added httpx to the list of supported http libs.
  • See full diff in compare view
GitHub
