Build(deps-dev): Bump webmock from 3.9.0 to 3.9.1 (PR #10667)
Bumps webmock from 3.9.0 to 3.9.1.
Changelog
Sourced from webmock's changelog.
3.9.1
Fixed support for passing URI objects as second argument of stub_request
Thanks to [Ryan Kerr](https://github.com/leboshi)
Commits
GitHub
