Bump acorn from 7.0.0 to 7.1.1 (PR #47)
Bumps acorn from 7.0.0 to 7.1.1.
Commits
  • 6d19489 Mark release 7.1.1
  • 793c0e5 More rigorously check surrogate pairs in regexp validator
  • b5c1787 Fix incorrect comment in regexp parser
  • 12ae8fe Parameterize dummy value and export isDummy
  • fa3ad8c Further refine acorn-walk types
  • 1d50286 Fix some errors in walk types
  • 97801f0 Mark acorn-walk 7.1.1
  • e9372c1 Further clean up walker types
  • de6edeb Remove NarrowNode from walk.d.ts
  • 1d85e7c Fix: acorn-walk type work with acorn's
  • Additional commits viewable in compare view
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
Looks like acorn is up-to-date now, so this is no longer needed.
